Conditional formula for YES/NO parameter
luis_brionesalonso
Message 1 of 12
luis_brionesalonso
I've been having an issue that I cannot resolve regarding conditional formulas for YES/NO parameter.
I have three YES/NO parameters: A,B, and C. A is only YES when a certain condition is met, B is a simple Tick Box (YES/NO instance parameter). What I want to achieve is the following:
If A=NO then C=NO, if A=YES then C=NOT(B)
or
If A=Yes then C=NO, if A=NO then C=NOT(B).
Does anybody know how you could possibly write a formula for C so that these conditions are met?
Replies (11)
Message 2 of 12
Luiscko
I think the best way is create two parameters yes and no, one for AB and another for C, when you obtain your first result then you can apply one script to Dynamo pretty easydfs.PNG
Luis Rodríguez
BIM Manager | Digital Transformation Lead
alt="EESignature" width="244" height="22">
Your Name
Encontraste util este post, compartelo y dale like para que llegue a mas personas como tú.
Si tu respuesta fue solucionada, te agradecemos que des click en el boton SOLUTION.
Message 3 of 12
luis_brionesalonso
I'm not sure I see how the Dynamo-script is applicable here. The parameters are meant to be used as visibility parameters in a detail family if it helps. The parameters have to remain seperate as well since the goal is to have parameter C=not(B) when A=YES and C=NO when A=NO.
A and B can vary independent from each other.
Message 4 of 12
or
Huh??? Makes no sense. It reads like C is never on.  If A and B are checked, C is unchecked.  If A and B are unchecked, C is also unchecked.
Maybe you mean this:
C=and(not(A), not(B))
Message 5 of 12
luis_brionesalonso
As mentioned above, A and B are independent from each other. So there are four combinations, not two.
what I want to achieve:
If A=no then C=no, if A=yes then C=not(B)
So if A=yes and B=no then C=yes
If A=yes and B=yes then C=no
If A=no then C=no, whether B=yes or no
Hope this helps you understand.
Message 6 of 12
Did you try the formula I gave you above?
C=and(not(A),not(B))
Message 7 of 12
chunton
Observer
Observer
Try this:
if(not(A), A, if(and(A, B), not(A), if(and(A, not(B)), A, B)))
Message 8 of 12
FAIR59
So in formula-language: IF(not(A),A,not(B))
Message 9 of 12
luis_brionesalonso
I'll try it out tomorrow, although I suspect that formula won't work since it reads as giving a YES value when A and B are NO and a NO value when A and B are YES, which is not what I am looking for. I think the formulas given below are the correct solution to my problem.
Message 10 of 12
Yep. It doesn't work with the conditions you spelled out in your second post.  I just threw that one out based on what you wrote in your first post:  "C" is OFF when "A" is ON or OFF.   Understandably, a little confusing.   Actually, the correct formula for that one would be: "C"=1>2  Smiley Wink
Message 11 of 12
luis_brionesalonso
Works perfectly, thank you. Smiley Happy
Message 12 of 12
luis_brionesalonso
It actually does work when you rewrite it to C=and(A, not(B)) since it should only be on when A is on and B is off in this case. Thank you for the suggestion.
