- Mute
- Permalink
- Report
Hi all. Our concrete material has a pattern which we only want to show in RCPs (which have been done for awhile) and in slab plans (which I'm working on now), but not in any floor plans. A while back I modified our floor plan view templates to control this, by unchecking Floor/Projection/Patterns. And I've created a ground floor slab plan which works fine (most of the slabs are building pads made of the same material). But now when I create our 2nd floor slab plan, I can't get the concrete material pattern to show up. The adjacent paver material shows up just fine (see screenshot), so it can't be the view template setting (and I've quadruple checked this, and attached a screenshot). I've also confirmed that the slab graphics are not overridden by view. What else could be causing this? TIA for any help.
