Revit Wall Properties name/tag issue
4 ANTWORTEN 4
Nachricht 1 von 5
mcondril
492 Aufrufe, 4 Antworten
The properties of my walls have values like "Wall-Ext_35Rsc-50Air-100lns-140Blk-12P" and I can't accurately choose the wall thickness because of this. When I watched youtube videos about Revit, I can see that their properties are different and it shows "Generic - 140mm Masonry" and I want to have those kinds of choices as well.
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: mcondril
I don't understand what you are trying to do.  "Wall-Ext_35Rsc-50Air-100lns-140Blk-12P" is a Wall Type NAME only.  It has nothing to do with the actual Wall Properties (e.g. Assembly Layers, Materials, Thicknesses).
Nachricht 3 von 5
mcondril
Hello Barth. Thank you for your response. I'm trying to create walls with a thickness of 140mm and 300mm but I can't determine which is which because the name of the wall type is written as "Wall-Ext_35Rsc-50Air-100lns-140Blk-12P" and not "Generic - 140mm Masonry" as seen in the picture below. I want to have the same list of options as these as well but I can't seem to find it in my Revit. Hope you could help me locate it.
Nachricht 4 von 5
There are dozens of videos and tutorials on-line that can teach how to create Wall Types.  Google can help you find them.
Here's one:
https://www.youtube.com/watch?v=Ere2_CT2k-s
Nachricht 5 von 5
mcondril
als Antwort auf: barthbradley
Oh I thought there is already a pre-set wall type in the software just like the ones I saw in the videos.
Anyhow, thank you so much for your help and the sample video! I appreciate it. Have a good day.
