Computer Upgrade Advice
I'm looking to upgrade my computer and would be grateful for any input as to what is the best option and configuration.
I want to spec the computer around Revit use.
Thanks in advance.
ennujozlagam
@Anonymous hello, you can check it HERE requirements to run autodesk products. hope it helps. thanks
Besides the written system requirements....hardware specs have been discussed quite a bit at Revitforum...  http://www.revitforum.org/hardware-infrastructure/
Many thanks for your help.
Thanks for the direction.
