compound Stair
compound Stair
Message 1 of 10
compound Stair
Hi every one. Can we have a stair like the attached file?
Replies (9)
Message 2 of 10
can anyone make this kind of stair?
Message 3 of 10
artejon
Do you have to model the stairs wih components made of different materials it is built or is it enough for you to make a fill region for different materials in a section?
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
Message 4 of 10
Thanks man.But how can i use different material in a component stair?There is only one part for monolithic material in this kind of stair?
Message 5 of 10
artejon
You can not have two materials like in your image.
You could use a trick to achieve that: if you want stairs to stay inteligent and parametric then model the stairs with a very thin run thickness, e.g. 1 mm then add the remaining part of a run as in-place component in stairs category. you will have to manually redefine it's shape if geometry of the stairs changes.
Message 6 of 10
I think this is a good idea.but it isn;t parametric modeling and also for construction we will encounter some problems
Message 7 of 10
Alfredo_Medina
Yes, I am sure you will have some problems building that type of stair.
Message 8 of 10
Is there any other solution for this?
Message 9 of 10
Alfredo_Medina
I don't know. Maybe you just did it already, as shown in the image that you posted, where you indicated what part is concrete and what part is brick.  I assume you are talking about a thin brick finish? Or are you talking about putting actual bricks in that small space between the diagonal and the horizontal plane of the tread?
Message 10 of 10
No it is a common stair in Iran.first we construct the slope of stair with concret then we use brick to make steps and make cover of stones or other material.I know it is not very professional but we construct it.
