Components isnt loading the doors...
Im trying to load in some doors from "place a component option" but whenever i choose  a door from the file, it says: "some of of the family files selected can not be loaded" why is that happening? i have attached a picture. Thanks a lot.
Is the door already loaded into project? If not, LOAD FAMILY then place an instance of it using DOOR on the Architectural tab, or dragging it from Project Browser, or right-clicking on it in the PB and selecting CREATE INSTANCE.
You cannot load a door via "place a component..." menu. Use the Door button then Load Family button to load.
RevitRx
Whenever this happens, go to the Insert tab and select Load Family all the way to the right. This is the blanket catch-all load if you're not sure the category.
www.RevitRx.com
KotairaKeila
is right.  Use (DR) or Architecture > Door, and then "Load Family".
