Can't save because Revit thinks I'm in Viewer Mode. I am not.
I am currently running the latest version of Revit 2019. I have been working on a model all day with the assumption that auto-save is in effect. I went to Save before closing out of the file and was informed that Revit is in Viewer Mode and therefore cannot. I am absolutely certain I am not in viewer mode.
I have also attempted to create a new file and Save that one as well with the same result. There is no warning or prompt when creating or opening a file that informs me I am entering into Viewer Mode, and the Windows Title Bar does not display "Viewer Mode" in the text.
Autodesk also auto-downloaded 2020 in the background while I was working. Maybe related?
Has your Trial Period Expired?
Were you prompted to activate when you launched?
See if the information helps:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
I have been a paying subscriber for nearly a year, so no trial period is in effect and I was not prompted to activate.
RobDraw
More than just related. It was the cause.
See this for 2020. I think 2019 needs to be reinstalled unless a fix has been released.
Rob
