Complex roof Structure
14 REPLIES 14
Message 1 of 15
apocalip
1401 Views, 14 Replies
Hey!
please be kind with me, i'm extremely new with Revit and currently working on a Model for an old House of mine. I do have years of experience in Fusion360 for Hobby Projects, but Revit is quite new for me (less than a Week).
I have a bit of a complex Roof which i struggle to replicate in Revit. There is a normal pointed roof and a second Building which is rotated by 90 degree, a bit lower and offset by half the building length.
Here's a Photo of that Building and the Roof section which i struggle with:
I already managed to get this far by creating the 2 roofs Seperately and then joining them and attaching the Walls to the roofs:
My current Problem is, that i'm clueless how to remove the Roof beneath the other roof. I already googled for quite a bit but can't seem to find a way/solution to achieve this. I suspect it kind of needs to be done with a cut or trim?
Here's the Revit file of my current state: https://www.dropbox.com/s/vchd6qgegyhagzi/Fachwerkhaus.rvt?dl=0
Would be great if someone could give me a hint or show me how to create that Roof properly,...
Thanks!
Cheers Marc
14 REPLIES 14
Message 2 of 15
in reply to: apocalip
Is this what your are trying to do?
Message 3 of 15
apocalip
in reply to: barthbradley
yea, that looks almost correct. Is the roof behind that Wall open as well?
Message 4 of 15
apocalip
I have a 3D Scan from Canvas, that was converted into Sketchup, which shows in 3D how it should be:
https://canvas.io/viewer/dwuRj73Y
Message 5 of 15
Okay, so this?
Message 6 of 15
apocalip
Yes! How did you do it 😀
Message 7 of 15
see if attached RVT helps...
Message 8 of 15
apocalip
well, you did close the Wall, but what i'm actually struggling with is connection/opening the Roofs on the Inside. I want the part of the Left roof, that is "under" the right roof to be gone, so there is a passage from the one attic to the other.
Message 9 of 15
Cut away part of the roof sketch then.
Message 10 of 15
mauricio_mssf
Take a look at this GIF I made to help another person with a similar doubt.
 To your roof follow the steps
Select the roof and Edit Footprint
1 - Select pick lines
2 - Select the exterior side os the roof 
3 - Select the line you created and uncheck the slope definition
4 - select Trim tool
5 - with Trim tool activated cut the lines to join in red
6 - with trim activated cut the lines to join in green
7 - Finish editing mode
Join both roofs
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
Message 11 of 15
Message 12 of 15
apocalip
perfect, thank you!
Message 13 of 15
@apocalip wrote:
perfect, thank you!
Solution credit would be nice payment for services rendered.
Message 14 of 15
apocalip
i did click on "Accept solution" of your Tutorial answer, or do i need to do something else?
Sorry, first question in this forum, so i don't now the etiquette yet.
Cheers Marc
Message 15 of 15
You have two different members helping you. Click on one of my posts and accept it as a solution. You can give out as many solution credits as you like.
