Common edges
Common edges
dieter.goris
Message 1 of 27
Common edges
dieter.goris
Is there a way to disable the common edges between walls?
I can only set the common edge lineweight once for a view, but then some of the lines are too thick, and others are too thin. For example, when I join 2 walls, I want the common edges between the walls to follow the lineweight of the wall itself (the thickes one). Is there a way to achieve this? Thanks!
Replies (26)
Message 21 of 27
PARTS! HOLY CRAP!  I wish I had thought of that. You're a legend, @ToanDN! 😉
Message 22 of 27
Feel free to explore and be familiar with Parts. You are welcome.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-M...
Message 23 of 27
Yah, I was being facetious. I suggested Parts 3 or 4 times before you arrived on the scene.
Message 24 of 27
You also threw the towel and suggested using Linework tool.  Again, I suggested you to read the Parts documents more thoroughly, it is more than just the Create Parts button.
Message 25 of 27
I think I could teach you a few things about Parts.  Have you read my book?
Message 26 of 27
I think I could teach you a few things about Linework.  Have you read my book?
Is it under the Humor section? Do send over the link
Message 27 of 27
