Can`t find grid in ifc... after export, why
3 REPLIES 3
Andreasdraxl
239 Views, 3 Replies
Hello Reviter,
i want to export my grids, better to say the grid information should be stored in Columns, walls, openings(Proxy),...
but for any reason it does not work! i tested several solutions...
KR
Andreas
it is weard, the grids are there but without information... in BIMCollabZOOM.
How can I solve this problem?
KR
Andreas
Mit freundlichen Grüßen
Andreas
Revit 2022
Dynamo 2.12.0.
Navisworks 2022>IFC4
3 REPLIES 3
mphungDCHNW
in reply to: Andreasdraxl
You may want to create a stand alone grid system and link it in your project you should be able to the grid in Navisworks after.
Andreasdraxl
in reply to: mphungDCHNW
Thanks!
i did this already...  but it does not work. It should work with BIMCollab. So when i create an Issue that is involved in an issue the grid should be added!  It does not work!
As you said, with the link grid it does not work...   also not isolated views!
KR
Andreas
Andreas
Revit 2022
Dynamo 2.12.0.
mphungDCHNW
You can always import a Cad showing grids and export if you want it like that rather no directly from Revit.
