Hey all, I know there are probably hundreds of posts on this issue, but the behavior seems to have changed recently so I'm starting another one. It used to be that when you joined an architectural wall to a structural column, the column would keep its hatch. This is not working for us any more in Revit 2023. The column goes white when it is joined to a wall. Switching join order does nothing. Is anyone else seeing this?
Unjoined:
Solved by ToanDN. Go to Solution.
Is this happening in Revit 2024?
Are you using a Structural Template?
