Column Base/Top Level Parameter Greyed out
BigPicture045
BigPicture045
I am looking for how to change the base/top level.
What's greyed  out?
BigPicture045
The top and base constraints. Cannot select/adjust them.
Is it in a Model Group?
BigPicture045
It was in a model group. For some reason you cannot adjust this setting of the column in the model group even if the model group is in edit mode.
To fix I delete the column from the group and then out it outside the group and then add it back in.
So, the answer to my 2nd question is "Yes".    😉
BTW, you can adjust a grouped column by Editing the Group.
therevitsith
Why can't you edit a columns base and top level when it's in a model group?
