Column and Retaining walls Intersection
In Case of column and retaining wall intersection,
How does Revit Calculate the Volume of the column and the RW
And How to force Revit to calculate the full volume of column and the rest volume of RW
Ilic.Andrej
following....
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Switch Join Order
Yes, It Worked with me, Thanks
I have a question related to intersection of objects too plz :
after i drew wall foundation ( PC footing ) all elements became dash lines ( columns , walls , col footings ) ... what does this mean ?36930984_1768769473170962_8589362175938658304_n.png
@barthbradley wrote:
Switch Join Order
Check Structural plan Level, view range, and type settings of structural plane, whether you looking up or down
