Colours/appearance not showing/rendering
stevensonJQWEF
stevensonJQWEF
Hi everyone,
I am using an IFC that I have now saved as a revit project (that i recieved from the architect we are working with).  What I am struggling with is the appearance of elements.  In the highest quality and when rendered they are completely gray.  However in the properties of the type and the material used, it shows a much more complex pattern.  Do you know why this real material appearance is not being shown? - or is there a solution to how i can make a nice realistic render in the appropriate material colours?
(I attach an image of how it looks in Visual style: realistic,  and then also one of the boxes showing what the material is set to)
Thanks in advance,
Nina
jvpantin2
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Linked-IFC-display...
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
