Creating A New Annotation Category in Visibility/Graphics Override
jack.edwardsNEWLG
jack.edwardsNEWLG
Community Visitor
Community Visitor
I'm pretty new to revit and i'm trying to figure out if there is a way to create a new Annotation Category in the box shown in the attachments.
I need a category that has all levels/grids/references unchecked for visual purposes and its slow doing it one revit link at a time.
Mike.FORM
Your attachments are missing.
jvpantin2
You cannot create a category but a sub-category. It must exist and be the same in both linked and host files.
I'm missing something, why a different category instead of using existing?
¿Tu problema fue solucionado? Selecciona 'Marcar como solución'.
Así ayudas a otras personas a encontrar respuestas y agradeces a los miembro de la comunidad.
jay_colcombe
I think what you’re asking is if you can group several Annotation Categories in the Visibility Graphics dialogue to turn them all off at once in links?
The quick answer is no!
The easiest way to do this is create a New View Template
In that View Template edit the Links field to Turn Off your listed Annotations above.
Then select ALL the links in the Project Browser > Right Click > Apply View Template and select the New Template you created earlier.
“Apply Template” uses the settings but does not force in the View Template as “Assign Template” does so is a great way to apply visual settings to multiple View/Links
Jay Colcombe
Autodesk Certified Instructor
RSomppi
Since you cannot create new categories, you should look into using view templates. They give you the ability to apply the same settings to multiple views.
