Colour schemes doesn't load
- Mute
- Permalink
- Report
Good morning everyone,
I wonder if any of you has had the following problem and, if you found a solution because it is really annoying.
I have always used colour schemes to show different uses, spaces, etc. Since a few weeks ago, when I choose a colour scheme (by room name, area name, etc) it begins to load and try to calculate the colours but Revit never finishes calculating the colours. If I try to sync or save the file, I can't do it as there is a message that displays "Can't sync, colour fills are calculating". So the only solution is turning off the colour scheme, which also takes ages to open.
Has anyone had this problem? I wonder if this is something related with the use of Windows 11? I have tried to turn on and off "Hardware acceleration" and it doesn't work either.
Many thanks in advance!
