We have a series of BOMA area plans in one of our projects for which we would like to use color schemes. The color fills, however, are not appearing like they should. Instead of a solid fill, they are showing up as a pink hatch. Any ideas as to what might be happening? See attached jpg.
That indicates that Revit is processing the data. If you look at the lower right of the screen you will see an icon next to the filter "Background Process". This shouldn't take long based on the computer you are using
Any news on this issue? I have the exact same situation, it's showing pink hatches, but there is no background process...
