Dear all, I tried so many times for that hatch pattern but still not yet correct. Pls help to create hatch pattern below image
Gelöst! Gehe zur Lösung
Gelöst von Pattycake_Kyle. Gehe zur Lösung
you can refer to this LINK and see if helps. thanks
Hey @Anonymous
Here ya go: https://pattycake.io/pat/YlRY9e4wveQ
This one was written by hand, you can learn more how to do that through this tutorial we put together.
However, you can also use this one: https://pattycake.io/pat/Yll1WNdrWGG
This was made (much) easier by just drawing it in our draw in web - you don't need to 'understand' the PAT syntax at all.
Both will function the exact same in revit. We've tested this thoroughly --- there is no performance difference/degradation in PAT files of this size (generally you are safe up into hundreds of lines before any issue shows up - and it has more to do with density of the PAT and tolerance/precision than # of lines).
:geburtstagskuchen:Cheers!
Night mode is dope mode
Draw in Web rocks our socks
The equivalent and equally efficient pattern is directly available on filling in block size and offset as shown in the attachment:
; Written by HatchKit 4 Standard Edition
; HatchKit 4 Standard Edition (c)1990-2021 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2021/05/28
;-Time : 18:13:53
;-HatchKit 4 Version : 4.1.4.3038
;-HatchKit 4 Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=INCH
*Phyoei,
;%TYPE=MODEL
0,0,0,0,300
90,0,0,-2100,50,300,-3300
hth,
Hugh Adamson
I am trying to create a custom hatch for a staggered, woodplank, random looking hatch.
I need it in 1220 x 230mm.
I tried to adjust this 100 x 800 pattern. But just don't get it to work. I even asked chatgpt, but it couldn't figure it out either. Can someone please assist?
;%UNITS=MM
*100 x 800mm Wood Board, Wood: Wide boards
;%TYPE=MODEL
0, 0, 20, 0, 100
90, 0, 20, 200, 200, 100, -700
90, 400, 120, 200, 200, 100, -700
How can I get this wood board look in 1220 x 230mm?
try:
; HatchKit 4 Standard Edition (c)1990-2023 Cadro Pty Ltd
;-Date : 2023/05/19
;-Time : 14:45:39
;-HatchKit 4 Version : 4.3.1.3212
;-HatchKit 4 Output Filetype : Revit® with HatchKit Fill Manager
;%VERSION=3.0
;%UNITS=MM
*230x1220mm Wood Board,Wood: Wide boards
;%TYPE=MODEL
0,0,0,0,230
90,610,230,-1380,305,230,-1610
90,0,0,-1380,305,230,-1610
hth,
Hugh Adamson
