Color of objects in 3D mode are not showing in elevations
gtdraftdesign
gtdraftdesign
When I view my model in 3D mode, the color of the window sash looks correct. However, the sash is white in elevation mode. Why would there be a difference between the two? I've included two attachments.
ennujozlagam
create a view template from your 3D view and apply to your elevation view in see if helps .thanks
gtdraftdesign
Thank you for replying. I tried creating template from view, and the sash still is white.
ennujozlagam
have you check your setting of detail level - fine  and visual style - colours and see if helps. thanks
constantin.stroescu
  • Are there your Elevation and 3D View in the same Visual Style?
  • Are there any override 2D Masking Region applied in Family Editor?
Constantin Stroescu
hmunsell
can you post the model, or at least that portion of the model, so we can look at it?
Howard Munsell
