Can I change curtain wall panel/type?
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
1200 Aufrufe, 6 Antworten
Right now I have just basic store front. I know you can add panels but is it possible to make the type of panels in the photo attached? Along with the frame around it (I guess the wall) ?
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: Anonymous
Use the Sloped Glazing (Roof) or Curtain System on Mass Face.
Nachricht 3 von 7
als Antwort auf: barthbradley
Sorry is that to slope the wall? I just want to change the panel or grid type if possible. And frame it instead of having it go all the way from floor to ceiling?
Nachricht 4 von 7
ennujozlagam
pick the curtain wall and adjust > edit profile to suit your need. thanks
Nachricht 5 von 7
martijn_pater
Not sure what panel we're talking about. To create a cw panel go to new --> family, select Metric Curtain Wall Panel family template. Model your panel, save&load it into project.
Nachricht 6 von 7
So, the only thing you were trying to illustrate with this screenshot, was a Curtain Wall without Horizontal Mullions?
FWIW:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Model/files/GUID-B9263125-74EA-4C78-AAAA-F40916EFE2DB-htm.html
Nachricht 7 von 7
Yes sorry for not being clear, still learning terminology. I finally took out the horizontal mullions but I don't want it to go all the way floor to ceiling. Should I just put in and edit a window instead of curtain wall? I'm so used to SketchUp..
