color fill legend
color fill legend
Mohamed_Arshad
Advisor Advisor
color fill legend
Mohamed_Arshad
Hii geniuses,
how to delete existing room color parameter and how to add new one, i cant able to remove value
kindly give your hands to solve it.
Mohamed Arshad K
Software Developer (CAD & BIM)
I'm not really sure what you're referring to.  If you asking how to change the colour, click in the Color column and change it to the colour that you would like.
constantin.stroescu
hmunsell
if your looking to add a new/different Scheme, you can select the Name option (upper Left) and pick Copy or Delete form the bottom left.
if you want to remove names i think you need to remove them from the model or pick a different option to display by
if all you want is to change the colors, do as @Anonymous suggests :-).
Howard Munsell
You can't remove a "Value" that is "In Use".
