Autodesk Viewer doesn't show custom wallpaper
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
709 Aufrufe, 2 Antworten
Hello!
I'm trying to apply some wallpaper covering to my Revit model. And then walk through the building using Autodesk viewer. But when I upload the model the wallpaper doesn't appear. If I use a standard wallpaper it appears well, but the custom wallpaper is not appearing. Can you help?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
What do you mean by "Wallpaper". Are you talking about Background Image?
Nachricht 3 von 3
als Antwort auf: barthbradley
Wallpaper - just the finish for the walls.
Never mind. The problem was that I didn’t upload the image patterns to the viewer with the Revit model.
Thanks!
