For a project I want to show the client an overall look of his building, combined with an 3D model. I would like to show my rooms in the 3D view, (color fill legend). Wouldn't it be great if a function came for this? Or is this implemented in the 2017 versions?
I got a workaround for now, by changing the graphics per view I color in a room according to the legends colors. Problem: when I want a color changed in the color fill legend, I have to do manualy in the 3D view as well. Plus, the graphics overriding takes unecessary time.
Revit LT 2016 user.
Revit LT 2016 user.
this might be tedious but you could create a mass object for each room object. you can then see the mass objects in a 3d view and change their visibility settings accordingly.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Not usable with Rooms and with your problem, but if you want to display anything in 3D in different colors without creating thousands of filters, you can Save As.. your project and create Worksharing. In that way you can assign different stuff to different Worksets and display them in different colours.
I think you have blown away everyone with that amazing trick..
Awesome solution and so many possibilities will come with that..
Cheers
Cheers
Thanks for compliment. It's work of my colleagues, not mine ;-). I'm glad to help.
