Collaboration for revit 2017 Trial-impossible to open files from the shared Hub
v.milan
v.milan
Hi!
I signed in to get Collaboration for Revit 2017 in the Trial version and apparently on B360 I can see that I have access to this Trial. I'm also sure I've been invited to a Hub shared with other people who are working on the model with a full license of R4C 2017.
When I open Revit in order to open a file from B360 I don't see any icons either in Menu>Open nor in Collaborate. I don't have any icons active (see screenshot attached-It's in Italian but I think it's intuitive). If I go in Mange models in A360 I can see the folder where I've been invited to.
Do you have any suggestion of what I did wrong?
Thank you very much!
Valentina
Cucu_Setiawan
I have the same problem, I am currently using the Revit 2017, in hopes of being able to put on BIM 360 Docs, but can not,
I switched to use FUSION TEAM that can collaborate in Revit 2017, but the tetep must be in the law also with BIM 360 Docs to be able to collaborate
Finally I used to be second, and FUSION TEAM as a data store.
