Test family 01 & Test family 02 has generic annotation family one placing in 2016 Revit with empty parameter there is a question mark (?) visible
Tested in different Revit versions (2016 & 2017). Revit 2017 has no question mark (?).
2 families are attached. please find me a solution. Thanks
Here's what I would do - I would give the offending label a yes/no visibility parameter so that the question mark does not show. when the parameter is blank
Actually, when I inserted the family in 2017 the ? was visible. Ghost in the machine, perchance?
Rina Sahay thanks for your reply
see the difference in 2016 & 2017
I looked at the family "2"; the one with the circle. If you delete the circle in the annotation, the question mark shows up in the project.
Have you considered using tags in the project to do this?
checked all settings in both versions of Revit. couldn't Find any settings difference
not using any Tags.
