COBie import or batch data entry for COBie
jallen158
Observer Observer
jallen158
Observer
Observer
I havent seen any recent post to forums so I wanted to follow up to see if there has been a feature added to import a COBie spreadsheet back into a Revit Model after updating data? Or is there a way to easily edit COBie data for multiple items as excel can be used for?
theslacollier
As of the latest updates, Revit does not natively support importing a COBie spreadsheet back into a Revit model after updating data. However, there are a few approaches you can consider to manage and edit COBie data efficiently:
Third-Party Add-ins:
Several third-party add-ins, such as CTC tools or Ideate software, are available for Revit that can help with COBie data management. These add-ins often provide functionality to import, export, and synchronize COBie data between Revit and Excel. Some popular add-ins include BIM Interoperability Tools by Autodesk and other specialized COBie tools.
You can use also Dynamo for Revit:
Dynamo, a visual programming tool for Revit, can create custom scripts that read and write data to and from Excel. You can use Dynamo to automate updating COBie data in your Revit model based on changes made in an Excel spreadsheet.
RVT to the max
handjonathan
Hi @jallen158
Thanks a lot for posting your question to the forums!   Has the solution suggested by @theslacollier helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
