Can't open MEP model
zachA2EL8
zachA2EL8
So every time I go to open our Plumbing model I get this error. Everyone else who tried to open the model gets this error as well. I have no issue opening our Electrical model though..
I have tried opening a central/local model, a detached model, audit in both central and detached. I have tried updating Revit. I even uninstall and full reinstalled Revit. I also have attempted to restore files from our back up server, and even the older files give me this error.
Any help is much apricated.
curtisridenour
Did you try the Open and Audit option within the 3 dots? I would also suggest opening "specified"  with all the worksets closed at the same time.
zachA2EL8
I'm not sure which three dots you are referring too.
This is in Revit 2024 incase I didn't specify
zachA2EL8
This is in Revit 2024 incase I didn't specifyScreenshot 2024-11-21 141026.png
zachA2EL8
closing all the worksets worked!
I was able to isolated the corrupted elements once the model was open. As i could edit it workset individually.
Thanks for the idea!
curtisridenour
Excellent!
I was referring to the 3 dots in ACC files on the far right side. This allows access to the options for opening files on ACC shown below.
