Cloud Rendering Aspect Ratios Change
stephenc9VRE3
stephenc9VRE3
Aspect Ratios of view are changing when rendered through autodesk 360 cloud. Images attached. Is this just a glitch today?
RDAOU
@stephenc9VRE3
Is this happening also when you render on the local maschine? Only cloud rendering?
Did you try recreating the views?
Select a preset aspect ratio from the list. To create an image with a different aspect ratio, select Custom Aspect Ratio and enter width and height values, or click the lock icon to the right of the width and height fields.
stephenc9VRE3
Tried duplicating the views and renaming, problem still persists. Although it seems to have corrected it's self on one image but not another. Something just seems glitchy.
stephenc9VRE3
Yes I set the custom aspect ratio but it doesn't seem to be translating into the cloud rendering. See attached images. This is fairly routine for me so it seems something is glitchy - I just thought there might be an update from the Autodesk team to clarify that they are having server/software issues. Maybe my file is corrupted and I need to re-establish it.
