Close polygone - quotation polygone
 someone can help me to undrestand why I can't close polygone?
This is the video
https://www.youtube.com/watch?v=RJAamQG1Lxw&t=334s
Command create form when check the poligone and perimeter to turn around to create form?
Second question:
there is a mode to quotate the polygone with angle when to octagone?
Thank's
L.Maas
Have a good look at the video and you will the presenter does it differently.
Notice that in your case you have lines dividing your octagon.
Also note that the presenter has the octagon positioned at a different angle.
Making the necessary modifications will allow the creation of the solid form
Louis
Please mention Revit version, especially when uploading Revit files.
Thank's for reply.
However can't to close poligone.
There is a command to put perpendicular the perimeter of form?
If is an otcagon the angle between vertical profile is 45/2 = 22,5.
Which is the command to put perpendicular te vertical and orizontal profile?
Furthermore there is an other way to rotate vertical profile to put perpendicular?
Can you give me your product?
Thank's
L.Maas
Not sure if I completely follow you.
For adjusting the octagon I just use a simple rotation command.
Pick the mid point of one of the lines and rotate that to the reference line
Louis
You also know why haven't architectural model like pics?
Thank's for before answer
