Cloister vault
2 REPLIES 2
449 Views, 2 Replies
Cloister vault
i did a cloister vault in the massing environmentas per  @constantin.stroescu  video and loaded it into the project. When i tried to make roof with tow options 1. Wall by face and 2. Roof by face. In both the attempts i didn't get the expected result.
 1. Wall by face
 when i used wall instead of roof, i get this unjoint corners as in the image.
2. Roof by face
 When i use roof by face option i get some extra extensions which i marked with the red lines in the image. When i tried to get rid of that extra extensions with the shaft opening tool it didn't help.
so can some one please help me to sort this out...
2 REPLIES 2
constantin.stroescu
1. Wall by face
  • you can choose how to place Wall by Face from: Properties >Constraint > Location Line
2. Roof by face
  • you can control the rim appearance from Properties > Construction>Rafter Cut settings
https://knowledge.autodesk.com/community/screencast/bda4e55e-6cf6-49c0-a3d8-b7c6cc61928e
Constantin Stroescu
in reply to: constantin.stroescu
Perfect...
Thank you very much...
