Cladding around a structural column
AidanHawkins
AidanHawkins
Hello
I want to add cladding around a strucutral column.
Is drawing a wall around the column the best practice?
Here is an image with the cad linked
@AidanHawkins wrote:
Hello
Wall is acceptable practice. There is no "best practice".  Depends on you and your requirements. In the real world, how will the cladding be applied to the Columns?
NOTE: You can use architectural columns to model column box-outs around structural columns.
Use Architectural column.  You can nest a shared architectural column in the structural column and associate parameters.  And don't get scared away by someone saying you shouldn't do it.
I wouldn't nest a two-level family into another two-level family.
But if you want to do it this way, then check out this video:
Revit 2012 & Nested Structural Columns Workarounds - YouTube
