Civil 3D Boundary is not showing correctly when imported to Revit
Hello Revit community,
Any idea why I am getting this warning below:
It happens when I link CAD from Civil 3D to Revit. Image below shows aside from the boundary (PINK LINES) I created, it also generates the whole toposurface although I did not select it from the list. I only want to see the boundary surface.
Thank you in advance, cheers!
Richie
I don't know if I understand correctly, but it sounds like you want to create a Split Surface (on the Massing & Site Tab).
Hi @barthbradley,
I already tried that but error. See below:
And I am not sure if this is the proper way to do it. Or maybe I am doing it the wrong way. I dunno if it has something to do with Site Settings.
Thank you for the reply @barthbradley.
Cheers!
yurikim
Thank you for your posting @Anonymous
Have you tried to import through Site Designer? Try this and see if you can get more accurate result.
Yuri Kim
Product Support Specialist, AEC
the boundaries can't touch each other. Modify one of them.
