Circular curtain wall
8 REPLIES 8
Message 1 of 9
agata.kujda
315 Views, 8 Replies
Hello!
I'm hoping to get some help. I used a curtail wall in circular shaped.  It is devided in 4 sections: curtain wall panel, glass panel, reception curtain wall panel and wall panel.
I did it in order to connecte easier curtain wall with floors. Wall panel in blue here:
However thi wall tak a cilcular shape instead of folowing the pannels.
Do you have any ideas how to made it streight?
Thanks !
8 REPLIES 8
Message 2 of 9
RDAOU
in reply to: agata.kujda
@agata.kujda
Use a curtain wall and change panels to basic wall (no mullions) and the upstand below your glass curtain wall will be segmented accordingly
You can either
  1. use the same curtain wall (ie: add a horizontal grid >> delete mullions and change panel
  2. Or use 2 stacked curtain walls
Message 3 of 9
Maybe Curtain Wall is not the best approach here.  Maybe making the curved Glass as a Basic Wall Type and the using 3D curved Beams for Mullions would get you a more aesthetically pleasing look?
Message 4 of 9
agata.kujda
in reply to: RDAOU
Thanks for your answear . I have plenty of cutains walls on 4 levels so I was serching for a solution that alows me to keep all elements together. I tried already seperating curtain wall and the wall base but it means tracing inclination of every single panel.
Solution 1 is what you can see above but instead of panel there is a wall (this is a part of curtain wall). I don't want to use panel doesn't connecte with floor so I can't cut them.
Message 5 of 9
agata.kujda
in reply to: RDAOU
I dont know if I expleined my problem well here. What I am looking for is how to make a wall to follow  the panels (which means no to curved like it is now)
Wall in blue 1. and panel 2
Message 6 of 9
agata.kujda
in reply to: barthbradley
Hello thanks for an idea, but for an execution project it will not work.
Message 7 of 9
RDAOU
@agata.kujda
  1. Offset the Curtain wall from base >> Add a Basic Wall below >>> Use Inscribed Polygon
  2. Alternative...instead of wall use Either a Custom Panel or a Mullion with concrete Finish
  3. Or if you are adventurous, you can use dynamo to place walls aligned to the Panels
2022 file attached
Message 8 of 9
agata.kujda
in reply to: RDAOU
Hello. Thanks for your message and awsome videos!❤️
Syteme panels do not allow unfortunetly multiply layers as I need. It would work perfectly with simple concrete wall.
I just have to accepte some limitations of Revit and go for normal wall tool propably.
Thanks again.
Cheers
Message 9 of 9
RDAOU
@agata.kujda
It is not a system panel...It is a custom panel and you can add to it as many layers as you wish
Forma Design Contest
Technology Administrators
