Chromium Host Executable Processes Running in the Task Manager
Why are these processes running in the Task Manager, when none of the Autodesk component are being used. It discharges the battery, it's noisy and and occupies a lot of laptops processing capacity. Please give solution without physically disabling them in the Task Manager which then stops the programs functioning properly? Thank you!
Corsten.Au
Log out of A360
check this..
https://forums.autodesk.com/t5/autocad-lt-forum/chromium-host-executable/td-p/5853579
Corsten
Building Designer
tried but three of them still running while working on revit 2017.
