Changing the view order on a sheet
VenB
VenB
I am adding Area view above Floor plan view, but it is masking the Floor plan. When I change the order of inserting the views on the sheet everything appears properly. The bad part is that all the sheets are ready with the inlined  Floor plan views  and I have to insert the Area View , remove the Floor plan view and then re-adding the Floor plan to appears above the Area View- this will take hours of boring work. Is there a way to quickly change the view order  (move forward/back) on the sheets? Thank you.
JasonKunkel
No easy way to do this, sadly. I don't know, but maybe a Dynamo pro can offer up some thoughts on how to automate it.
In the meantime, you aren't the only person with this desire:
https://forums.autodesk.com/t5/revit-ideas/change-order-of-overlapped-views-on-a-sheet/idi-p/8141178
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
