Changing scales of interior elevations
2 REPLIES 2
DavidRaines
2281 Views, 2 Replies
I am having problems with interior elevations being projected at the wrong scale. I got a detailed plan from my floor plan so I could complete my interior elevations. But the elevation are coming out the same scale as the original floor plan and not the detailed larger scale floor plan. I looked for view scale for changing and could not find it. So I need help.
I have Revit 2018
David
2 REPLIES 2
Sahay_R
in reply to: DavidRaines
In the view, look at the bottom left hand corner of the screen. Click on it, and you can pick whatever scale it is that you want.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
If the View Scale is not editable thenCapture.PNGCapture1.PNG you have assigned a View Template to the elevation views?  Either create a new View Template with the new scale and assign it to the elevations, or uncheck View Scale from the Template then let it controlled per View.
Forma Design Contest
Technology Administrators
