You shouldn't, don't need to rotate the building link. It will rotate with your model if you are providing the site information correctly. There are so many (too many) ways to define the building's site position. Once done any plan view can be either True or Project North, see the Orientation parameter in the view's properties.
Each of these tools does some or all of the tasks required:
- Acquire Coordinates - Depends on a linked file and assumes it has the survey coordinate system defined properly, which is probably not true based on your posts, unless you have the surveyor's dwg.
- Specify Coordinates at Point (SPaC)- Click to identify a location in your building that your surveyor has provided site coordinates for and provide the building rotation. You may need to create something you can click on to use it, like a Model Line or a wall element.
- Rotate True North - Set the view to Orientation: True North first. Then select the tool, click to define rotation origin and then click to define the first side of the angle and then a second to define the actual angle.
- Project Base Point (PBP)- You can enter the coordinates and angle for rotation directly into this icon (you mentioned it earlier). This shifts the Survey Coordinate System away from the Project Coordinate System. It's the same result as Acquire Coordinates but does not depend on an external file being selected. To use it for your situation, it also assumes that the coordinates you've been given are what the current location of the PBP is now.
- Relocate Project - It's the same as entering values via PBP without the elevation input when used in plan view. You just move the building but it means you have to have some point of reference to move it to. To use it for vertical position (elevation) you need to use it again in a section or elevation view.
- Survey Point - Move it to a specific location while clipped.
Personally, based on what you've written earlier I'd use Specify Coordinates at Point. Move the Survey Point (un-clipped) to sit on the location your surveyor provided coordinates for. Then start SPaC, click on the Survey Point origin. When the dialog appears enter the coordinates, elevation, and rotation values.
Also, make sure your project units match those of the coordinates provided. Otherwise tiny amounts of rounding will occur in the input values. For example if the coordinates have six decimal places then change the units to match that. After using SPaC you'll find the same values are reported and maintained even after returning the project units back to their original settings.
Steve Stafford
