Changing level view indicator blue to another colour
Message 1 of 22
Is their a way of changing the blue that is shown on a level when there is a referring view to another colour? it is a little subtle for my liking and would like to make it more obvious feedback that their is a view associated with that level.
Replies (21)
Message 2 of 22
Not that I know of.  But you could change the Level head family to a color that is more contrast to blue color.
Message 3 of 22
Sahay_R
To edit the color of the Level bubble -
Duplicate and edit the family to whatever you want it to be - as long as it is compliant with your company's standards!
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 22
kamaluddin.shaikh9
its not working
can u please send a short video clip,
Message 5 of 22
kamaluddin.shaikh9
its not working
Message 6 of 22
RobDraw
What isn't working?
What are you doing?
Rob
Message 7 of 22
Sahay_R
@kamaluddin.shaikh9  here is a step by step approach -
Step 1
Create a new level head family
1) In Project Browser, locate the  Level Head family under Families>>Annotation
2) Right click >> Edit. This will open the family in the Family Editor.
3) Save As the family under a different name. Make the desired edits. Load the family back into the project.
Step 2
Create a new level style
1) Select a level
2) In the Properties palette - click Edit Type>>Duplicate
3) Rename the new style
4) In Type Properties >> Symbol, select the new head family
Now you have a new level style that you can assign to the desired levels.
Rina Sahay
Message 8 of 22
kamaluddin.shaikh9
i want to change symbol color of level head bt its not change,
Message 9 of 22
RobDraw
Do you mean the blue ones?
Rob
Message 10 of 22
kamaluddin.shaikh9
hw i can change the symbol color plz explain
Message 11 of 22
kamaluddin.shaikh9
yes
Message 12 of 22
Sahay_R
@kamaluddin.shaikh9  did you follow the steps from my previous message?
Rina Sahay
Message 13 of 22
kamaluddin.shaikh9
yeah,
 i follow the steps bt its not working
Message 14 of 22
You cannot change the blue color.
Message 15 of 22
Sahay_R
@kamaluddin.shaikh9  , @ToanDN is correct - you can change the color of the level head to whatever you want it to be, but as soon as a plan view is created for that level, the level head symbol will turn blue, This is how Revit distinguishes  levels that are associated to plan views.
Rina Sahay
Message 16 of 22
kamaluddin.shaikh9
2017 version
Message 17 of 22
I just spent an entire, excruciating hour of my life on trying to change the colour to something other than blue.
This is exactly the kind of stupid, illogical exception to the general logic of the software that makes you completely go mad while using Revit.
You know, it's not simply that this blue colour is hardwired into this particular family. I can live with that, even though it is kind of annoying for an architect if you can't control the colour scheme of your layouts completely (small hint: this is a point where ArchiCAD is miles ahead of Revit).
The problem is that there is no indication that this one thing is working differently to all the other families. And then, of course, I am looking for a solution until I go crazy.
Message 18 of 22
RobDraw
Yeah, Revit would be so much better if it had the ability to change the color of the heads like you can the foot.
Rob
Message 19 of 22
AlexscallyFFA
Observer
Observer
If you use DiRoots/ prosheets to export your drawings you are able to untick the box 'View links in blue' to make sure all levels appear black
Message 20 of 22
Thanks for your contribution.  However,  the discussion is about the color displayed in Revit, not the color when exported.  By the way, what you said can be done within the Revit built-in print settings, no need for any add-in.
