Message 1 of 20
Changing imported file material in Object Styles does not work
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all--I have been trying to import a file from Sketchup 2017 into Revit 2020 with the ability to change its materials. I saved the file as a Version 8 with each layer having a texture and all groups and components exploded.
Moving it into Revit, I did Insert → Import CAD → File Type: .skp; Colors: Preserve; Layers: Specify. In the Consistent Colors visual style, it looks like it recognizes the different layers with different colors.
I then went to Manage → Object Styles → Imported Objects tab and changed the materials accordingly for each layer. However, none of these show up with I render. Any suggestions moving forward? Should I import a different way? (I have Rhino so I could import and .3ds or .dwg or ACIS)
