changing file extension from ".rte" to a .rvt file
Archiez
Archiez
I am using the student version revit 2017. Apparently, I started my file as a template file, ".rte file" and now that I have most of my work done, I am unable to set up central model sharing for my partner to edit. Ive tried switching the extension name, by renaming to .rvt, "project file". However, when I attempt to open the file, it will not open. I get an error message stating file is not valid, and to rename back to .rte. I don't want to create a new file, or attempt to copy and paste and risk having to start over. What can I do about this?
Thank you.
ennujozlagam
@Archiez hello, try this go to the top left corner Big logo "R" > new > project > create new > set to project > browse your filename .rte file > ok > once your file open > saveas to project > give filename. hope it helps. thanks
