Changing dimension parameters on Revit 2020
Message 1 of 8
Hi there.
I just installed Revit 2020 (student version) but when I try to start a new project using an architectural template ALL dimensions, walls, windows, doors, etc are shown in inches and not in millimeters. I am in Australia and we use the metric version here.
Any idea where I should go to change this?
Kind regards
Marcio
Replies (7)
Message 2 of 8
PavelAnd
Hi @Anonymous . What project units are you using? Look this link and check it.
Best regards, Pavel Plotitsyn.
Message 3 of 8
PavelAnd
Other way is change type settings.
Message 4 of 8
ennujozlagam
you need to change your family template default. go to options > file locations and change all your defaults to english. thanks
Message 5 of 8
RDAOU
@Anonymous
Considering that this also affects the families/family templates which you have downloaded (all in imperial); you might need to consider downloading the Metric Templates from the following link and set the folder path in Revit to point to the new templates. (R>>Option>>File Location)
https://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/autodesk-revi...
Alternatively,
  1. Open the Imperial Template
  2. Go to Manage >> Project Units
  3. Change the units/precision...etc
  4. Save as >> Template
    •  Either overwrite the old one
    • Or save it as a new template Metric and add it to the file location in Options
Message 6 of 8
hmunsell
does the student version not have a Metric template?
  • open Revit
  • New...
  • from the New Project window pick Browse button
  • navigate to C:\ProgramData\Autodesk\RVT 2020\Templates\US Metric
there should be a list of metric templates to pick from.
Howard Munsell
Message 7 of 8
Message 8 of 8
Thank you very much! It worked.
