When I convert my RVT file to a image - it does not include various features including components. For example, I have inserted desks in this section of my floor plan - see attached screenshot. Also not shown are some walls and room seperator lines between rooms (Please note this was originally a CAD file and I inserted Revit over it). Whilst the other attached file just shows the floor space. Does anyone know what might be causing this issue? Thanks, Sam
i just tried and works fine, can you share share some part plan so we can check. try to install latest updates from autodesk and see if helps . thanks
I tried to move just a section to another file, however since it is a hybrid (combined with CAD) it complicates things. I also can not share the file due to confidentiality reasons.
I installed all new updates to Revit but it did not solve the export issue.
sorry to hear that. can you copy and paste that has the issue into a new file and try to export to image and see what happen , i'm just asking you only the part plan and not the whole project file which you can copy and paste into a new file, it is difficult to suggest without looking the actual file. thanks
