Changing Dimension for Model from one side
I recently upgraded to Revit 2022 from Revit 2017.
I am trying to change the dimension of a generic model from one side only (i.e. when I change the length of the dimension it will only change from the face/side I clicked on before I click on the dimension).
This always worked for me in 2017 and saves a lot of time. For some reason when I click TAB to single the face/side I want and then click on the dimension it does not allow me to change the dimension. I would have to select the entire model to be able to change the dimension and even then the change will be from the center not from the face/side I want.
Please see video for clarification.
Thank you.
Can you share that file?
