Changing Color Of Linked Model
mlhier
Message 1 of 8
mlhier
I am trying to change the color of a linked model to be black in ceiling plan. I've tried overriding the model in visibility graphics and applying a filter to the workset its in. Neither of those things worked.
Does anyone have an idea of what else I can try to solve this?
Replies (7)
Message 2 of 8
ennujozlagam
see this previous thread and see if helps. thanks
Message 3 of 8
mlhier
Yes. I looked at that previous thread and tried all of the solutions. None of them worked. Any other thoughts?
Message 4 of 8
syman2000
Check and see if your model map to correct phase. If the link is map to existing, it will use your phasing as your override.
Message 5 of 8
mlhier
The Phase Mapping appears to be set up correctly.
Message 6 of 8
syman2000
Can you check which discipline you are using?
As well check and see if your view range set higher than the ceiling display. As well check what underlay is set to. If you have underlay set and your view ranger is lower than the ceiling, it will show your ceiling as half-tone. If you change the view depth beyond the ceiling, it will show the ceiling as black line.
Message 7 of 8
mlhier
This is what my discipline and view range are set to. Neither of these seem to be the issue.
Message 8 of 8
syman2000
you may want to upload the sample file so we can see what is wrong.
