Change Unit In Single View
rawezh
rawezh
Is there an option to change units in one view not entire the project? for example I use meter unit in the project, but for some details in some views in the same project I want to use centimeters or millimeters, thanks
mhiserZFHXS
Probably shouldn't be on the idea board...
But just create a new dimension type like you would a new door or a new wall. Call it "detail dimension" or whatever you see fit, and change the unit format.
rawezh
Thanks. I appreciate It, that's what exactly I want, thanks again & again
