Change toposurface material
8 REPLIES 8
Message 1 of 9
good_man_27
509 Views, 8 Replies
Hell all,
I subdivided the toposurface area so I can apply different material to different regions. The first region I tried was the driveway:
The driveway surface need to look like the porch surface. I applied the same material, but only the colour changed. I need the surface pattern too. Any idea how to achieve this?
8 REPLIES 8
Message 2 of 9
in reply to: good_man_27
My guess is that porch hatch is a Cut Pattern, and the View Range Cut Plane is cutting through the Porch and above the Sub Topo.  How'd I do?
Message 3 of 9
good_man_27
in reply to: barthbradley
This is the setup I made for the porch surface:
And it does look the way it should. I tried to apply the same material to the driveway subregion of the toposurface, but only the colour was applied. However, I also need the surface pattern to show. How can I achieve that please?
Message 4 of 9
See if changing the View Scale does anything.
Message 5 of 9
good_man_27
I tried lower values to 1 and higher values to 5000. It didn't change.
I know I  can create a floor to the shape of each toposurface subregion I need, but that is a lot of extra work! Revit provides subregion command mainly to change the surface material. Why doesn't it apply it with surface patterns? Am I doing it wrong? PLEASE HELP!
Message 6 of 9
AH! TOPOSURFACE! I thought we were talking Toposolids. My bad.
Cannot add surface pattern to toposurfaces in Revit (autodesk.com)
Message 7 of 9
good_man_27
Thank you.
I haven't even heard of Dynamo before, or toposolids for that matter!
Do you happen to have a code I can use that can generate a slab on the surface of Toposurface? I'm using Revit 2023.
Message 8 of 9
You don't need Dynamo.
Follow these steps to create hardscape from your Toposurface Subregion:
  1. Isolate the Subregion in 3D View
  2. Export to DWG the contents of the 3D View
  3. Go to Massing & Site Tab: Conceptual Mass Panel and press In-Place Mass
  4. Go to Insert Tab: Import Panel and press Import CAD and choose the DWG created in Step #2
  5. Press Finish Mass to close out of In-Place Mass environment
  6. Go to Massing & Site Tab: Model By Face Panel and press Roof (or Wall) by Face and then select Mass Faces to host Roofs (or Walls).  Use a Roof Type or Wall Type that represents your hardscape composition.
Make Hardscape Follow Site Topography and Site Topography Follow Hardscape in Revit | Autodesk Unive...
Message 9 of 9
good_man_27
It took several tries, but eventually it was a success! I built using Model by Face - Roof.
@barthbradley, Thank you so much for your help mate. I really appreciated it.
Forma Design Contest
