change the visibility parameter location
A_MAQ
Advisor Advisor
A_MAQ
Hello all,
i have created a visibility graphic parameter under graphics
after i finished creation i want to change the location of parameter to be under identity data
how can i do that?
thanks in advanced
Autodesk Expert Elite
L.Maas
Close the boxes as on your screenshot.
Go to "Family Types"
Select the parameter you wish to modify and "Click Modify" or if you have the latest update click on the icon that looks like  a pencil.
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
YES YES I HAVE DID THAT AS YOU REPLY ON PREVIOUS POST
THANKS
RDAOU
Same/Related thread and question discussed and SOLVED HERE (ACCEPTED AS SOLUTION)
A_MAQ
thanks RDAOU
I KNOW I HAVE SOLVE IT
RDAOU
That was not for you...we know you SOLVED IT but this forum also serves other memebrs in finding solutions to similar problem. When someone runs accross this post they should be redirected via the link to the original post where it has been marked SOLUTION
You get it now?
A_MAQ
YEAH I GOT IT
