change the dirction of elements( angel element)
anass2010
Message 1 of 8
anass2010
I Can not change or rotate the elements as  i clearify in pic attached
Hoping to help me
Replies (7)
Message 2 of 8
josh.goldstein
Hi @anass2010,
Unless this element came from Forma (it doesn't appear so), you may want to post this question in the Revit forum.
Thanks!
Josh Goldstein
Senior Product Manager
Message 3 of 8
anass2010
ok Thanks
Message 4 of 8
anass2010
Hoping to help mScreenshot (943).pnge
Message 5 of 8
azad.Nanva
you can use the family like this one.
Message 6 of 8
anass2010
The problem not at family, actually, the dirction as pic I need is like freeze or I can not do it.
Message 7 of 8
azad.Nanva
if i understand, you need to change the direction or rotate the structural beam and column, the normal with chose direction of your drawing make a mirror element for u, but for make the rotate you need to change the Cross-Section Rotation and this make a great problem , he rotate the direction of element and axes too.
for this problem i make the new family with extra variable that have no problem to change the direction.
i hope the picture help more.
Message 8 of 8
azad.Nanva
pics
