Change the color of a Raster image in Revit (2020)?
cjacobsLDX59
cjacobsLDX59
Hi all,
So I have a raster image (specifically an imported pdf) in a 2-D view in Revit. I'm looking to compare its content to the drawing that I made myself, so changing its color from black would be ideal.
Is there any way to do this? Or any way to change the colors of the elements of the drawing that I made in Revit, even?
All help is appreciated :)!
Thanks in advance,
Not in Revit, but you can do it externally.
https://www.adobe.com/uk/acrobat/resources/pdf-to-greyscale.html
RDAOU
@cjacobsLDX59
Use a Temporary view template or a view filter that overrides all model elements (Cut and Projection) to a different color ... Red for example
