I started my project in the usual project organization and then switched to the phase organization with the floor plans/walls/etc already done i made the phases Existing and New Construction in Phasing Project Phases i changed all the elements instance properties to Phase created: existing Phase demolished: New then i made the New phase floor plan with elements instance properties Phase created: New; the phase filter on Existing views is Phase Filter: Show all Phase: Existing Show Previous+New Phase: New Construction
So now I go to South Elevation (Existing) but when I open the Roof level it is still linked to the Roof plan in the New Construction; so question How can I change the Roof level in Existing to connect to the Roof plan in Existing, because now it is connected to the incorrect plan phase (New construction instead of Existing)
Thanks in advance.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Thanks in advance.
Existing Roof Plan view: Phase = Existing, Phase filter = Show Complete
